Hello,
I'm going to get some 3/4 or 1 inch ply to make a build jig to layout my floor of my car on, what have people used to keep the tubes in the
correct position
little screw blocks from any diy place
B and Q ect Around a quid for 20
[Edited on 12/6/07 by big_wasa]
Same as ^^^^^ plus I made up strips of flat bar with holes at either end, placed them over all the main tubes and screwed them into the base board.
Alex
Mines the same but my blocks where made of 25mm square x 50mm lengh wooden blocks.
Thanks Guys,
Went to B&Q got the blocks, pick up the wood tomorrow morning as I wasn't sure on the measurements I needed
how sturdy have people found different ply thicknesses to be? If you have it on tressles how much support does it need to have less than a mm flex? sorry for the hijack!
good god that looks solid!
i was thinking of getting 6 800mm wide kitchen base units, 3 on each side back to back, with a 1.2x2.4m board on top. This only supports it every
800mm though, so i then though that i could put notches into the top and put a metal frame under the ply. Easy to get it level due to the adjustable
legs, plus lots of storage underneath!
