Anyone nows the screw used on the that wisbone??????
It's M12 or more?????
Best Regards
joćo Martins
www.martinsportscar.com
Yeah its M18. Assuming that its a transit trackrod end, which it isnt.
So its probs not M18
[Edited on 25/8/03 by JoelP]
Wouldn't this be better in the MK section?
Chris
Do you have shore that it's M18????? It sims less.
Can anyone that have one MK Indy confirm that????
Best Regards
Joćo Martins
Anyone can comfirm this information?????
Best Regards
Originally posted by Martin Sports Car
Are [Do] you [have] sure [shore] that it's M18????? It seems [sims] less.
Yeah, i thought that it was and then looked at it, its not a swivel thing. Send MK an Email, by all accounts hes a helpful nice bloke so im sure he
wouldnt mind.
Failing that just measure it when (if) you get one!
Does MK ever come on here?
Yes, Matoso at the end I think to use M12, but as you see some months ago the Bearings sims to be fragil, I speak with the guys from Fisher and they
tell me that they use near from M14.
Bets Regards
Joćo Martins
I don't understand why any builder who have one MK Indy don't replay only on that question, but ok..........................
Best Regards
Joćo Martins
I am building an MK Indy. The thread that you have pointed at is part of the MK design, I don't think it comes from another vehicle.
It is definitely bigger than M12 but I have no means of making an accurate measurement.
Seeing as MK supply all the parts in the kit (the thread and three nuts per side) I don't see how / why any MK builder would need to know the
size.
MK really is the best source for that information.
Sorry I can't be of any more help on this subject but I thought you might want to know why the responses may have been poor.
Russell
Thanks Russ It's sufficient your information.
when I start mine I plan to M12 but know I will change to bigger dimention probably M14.
Best Regards
Joćo Martins
Joćo,
I'd start at M18, this is a large diameter threaded rod.
The nuts are about 30mm across the flats and the thread looks to be about 20mm.
Russell
Thanks,
Russel
Best Regards
Joćo Martins
