I've been roaming the Middy section for almost a year now, but stumbled upon a Mazda B6 SOHC lump yesterday. So I decided to build a seven-esque
instead. It's the perfect start to design engine mounts while I source a DOHC version from a Miata and consider ITBs.
I am an engineering tech student and spend much of my day in the shop, so the goal is to have as many fabricated parts as possible. However, I will
spend much of the next few months modifying the McSorley design to suit my particular needs and working out both front and rear suspension designs
with simulation software.
I look forward to sharing updates with you lot. 'tis a slippery slope I'm on...
