wall thickness flat oval wishbone tubing
Mave - 22/1/08 at 12:41 PM
What's the wall thickness of the flat oval tubing a lot of manufacturers use for their wishbones?
big_wasa - 22/1/08 at 05:28 PM
32mm x 16mm x 2mm wall
But I am buggered if I can find anyone that stocks it
paulf - 22/1/08 at 08:51 PM
Theres a steel supplier in Corby that i asked who could supply it in a range sizes but they had to order it in.I would go for 1.5mm wall thickness though.
Paul.
procomp - 23/1/08 at 08:08 AM
Hi it has been tried in 16g and did not work for long. Although that was a fairly wide track car. Nether had any problems with the 14g even with very wide track.
When trying to order ect don't ask for OVAL as that is true oval. Ask for flat sided oval furniture tubing. Most should carry this in stock in various sizes.
HTH cheers Matt
Mave - 23/1/08 at 09:08 PM
How much is 14 gauge in mm?
I know 16 gauge is something like 1.6 mm, but never understood the logic behind a higher number being a smaller dimension. Is it 2 mm?
iank - 23/1/08 at 09:14 PM
http://www.simetric.co.uk/sigauge.htm
14gauge is 2.03mm
Triton - 23/1/08 at 10:50 PM
AH Allen in Northampton stock it and call it flat oval...14swg is 2mm wall....like you say the higher the number the thinner the gauge....damn potty if you ask me!!!
Mark
Cousin Cleotis - 29/1/08 at 07:01 AM
Ralt Engineering, 32 x 16.7 x 2 CDS2 £7.05 per metre.
Paul
