Pretty much finished my chassis apart from a few bits of welding but what do i do now?
Still have yet to fit the floor and make the suspension and front wishbone brackets but do i paint the chassis first?
Also, do i get the fuel tank made and get the engine running before painting?
Its been a long day i my brain cant work hard enought to work it out
is the frame coated in anything? If not I'd paint it next, or it might rust horribly, and I wouldn't fancy grinding off rust with an engine
in place, just because it would be a pig to keep everything clean.
Whipping out a 1.5 tonne engine isn't a five minute job
get your suspension sorted first, as brackets need welding on. I would get it built up before painting to ensure you dont forget any brackets! How are you attaching the floor and what material?
i would at least get the suspension brackets and engine/gearbox brackets all welded on then paint it.
rob
In a perfect world I would get the car as near to finished as possible , then strip it for paint . No matter how thorough you are there will allways
be brackets and bits to add.....
paint in oxide primer now, but don't give a final finish tll the chassis's complete and all your trial fitting of rngines and stuff is
done.
do the floor before painting primer though, if the floors being welded in
you can buy weld through paint, works well to protect the metal and you don't have to bother removing the paint when adding a bit.
