Hi chaps A newbie to all this. Got a mac1 worx on order I posted a topic what tools i need?
People say rivet gun some say rivnut??
what is best know they do different jobs but is the general idea to use rivnut instead of rivits to remove panels at a later date???
thanks
Buy both.
You won't regret it!
You can get away with a cheaper Rivet gun, but cheap RivNUT guns aren't the best. But it all depends on budget and I don't know yours!
I would also buy a lazy tongue rivetter if you want to be able to use your forearms after doing your floor......
HTH
[Edited on 25/5/08 by worX]
Both!
You'll need a rivet gun to fix things like the floor panel, i.e. those panels that need to be permanently fixed
And
a rivnut gun to fix things that can be removed later i.e. rear wings.
HTH
Mike
P.S. I had virtually no tools when I started my build (when I needed loads) and now it's finished I have a tool cupboard full of them which
rarely get used. How does that work!?!?
rivet gun - buy one with a swivelling head - axminster tools and frosts sell them.
really really handy to get into those awkward spots.
contrary to what has been said, panerl held on with pop rivets are removeable - you needto drill off the rivet head - the rest ofthe rivet will drop
into a chassis tube so if you do this too often and are unable to fish it out, you will see the weight of your car increase overtime
you needto drill off the rivet head - the rest ofthe rivet will drop into a chassis tube so if you do this too often and are unable to fish it out, you will see the weight of your car increase overtime
Unless you want aching arms get a compressed air rivit gun, these are fantastic. You will only need a small compressor to run one.
Originally posted by Danozeman
And they rattleso spray through the hole with waxoil to hold the bits.
someone on here (petef ?) has the plans for making your own rivnut setting tool. I gave my dad the plans and got one back the next day.
