I was bored tonight so I started drawing up a chassis on CAD so I can develop body designs, Enjoy...
[img][/img]
well no ones ever done that before
Haynes Roadster If I'm not mistaken
Some more work on it tonight, did the rear section which was a bit more challenging as this is the first time ive used the program and its different
from the other programs ive used in the past.
[img][/img]
What sofware did you use?
I use Autocad (albeit to design houses not cars) and was thinking of dabling in drawing up a chassis, (mainly for fun rather than the build)
That is just using Autodesk 3ds Max 8, its not the most accurate but does nice rendering and is great for bodywork etc.
Im tempted to draw up the plans in 2d on autocad then import them to sketchup as thats ultra easy to use.
That's Sketchup from Autocad.
Sketchup is fabulous
Chris
What chassis is that drawn from (if any)
That's probably a Haynes Roadster, I think.
Chris
