Well some progress at last, picked up a pair of 7inch compomotive ML's the other day so got my tyres fitted ASAP. After I finished work today I
went and picked up a lot of the bits I had lying around, threw them in the car and off I went to Forfar.
Arrived up there and got the chassis off the trailer and onto the ground and made up some dummy damper units, bolted the rear brake discs and wheels
on leaving me with this...
Rear from a bit back
Rear/Side
Rear Wheel
From the Front
Rear Hubs
View from the rear
Rear from above
It was then onto the front, I fitted the two new hub bolts that were needed but when we married up the upper ball joint that came with my front hubs,
the thread diameter was different, so had to drill out the wishbone and tap in the correct thread. It was then a case of making some front dummy
units, fit the front wheels, stand back and enjoy...here are loads of pictures that I have taken because I was so happy to finally see it rolling
Front "Suspension"
From the rear/side
From the front/side
From the front
Front Hubs
Front from passenger side
Dave Drifting
Me very Happy
Daves action shot
Self-timers
Well im very very happy, and I should be moving into my new garage in the next two weeks so main building can start
Cheers Mark
Looks great!
Looking good, like the wheels too (13's?), Are the tyres road legal, and what width are they? I've been looking for wide tyres for my
7" revo's
Alex
Originally posted by ecosse
Looking good, like the wheels too (13's?), Are the tyres road legal, and what width are they? I've been looking for wide tyres for my 7" revo's
Alex
Don't know if you noticed, but you have your front upright on backwards, eg the left on the right and vice versa, your steering knuckle is pointing to the rear
Looking good.
<obligatory> those shocks look a bit hard! </obligatory>
Is it just me or are the front uprights both on the wrong side??
Hi Alex, the alloys are 13inch Compomotive ML's, the rears are 8 inch wide and the fronts are 7inch. These ones are not road legal, but you can get the road legal versions that have a slighlty harder compound. The Front tyres are about 185/55/13's and the rears about 215/55/13's.
Loving the locost axle stands.
Those wheels are lovely. (So is the Alpha currently on Top Gear!)
fantastic mate looking really good
