chassis Recommendation for a pinto
thwang - 6/9/08 at 07:08 PM
hi all
newbie question
will the pinto fit straight in the standard book chassis or would it be better to build the 7+4 or the 7+442 or how low can you fit the engine i think my old mk2 mexico sum was about 3 1/2" front the ground.
thanks inadvance simon
speedyxjs - 6/9/08 at 07:15 PM
Should fit ok but the mounts will have to be relocated
thwang - 6/9/08 at 07:46 PM
thanks speedyxjs
thwang
Mark Allanson - 6/9/08 at 08:13 PM
Loads of people have done it, a bit tight but not difficult, you will need a small alternator and a fabricated bracket. Chop the sump level with the bellhousing, move the oil filler to the back of the rocker cover.
scutter - 6/9/08 at 08:30 PM
Why not try what i've done, which was to add an inch to the chassis height from the "H" tube at the rear of the dash forwards, it's allowed a zetec to fit nicely
ATB Dan.
The Baron - 7/9/08 at 08:12 AM
I,ve got a standard chassis (original BYOSC for £250) with a pinto sat in it, the transmission tunnel will need to be different (wider) if you are going to use the type 9 gearbox.
B
Peteff - 7/9/08 at 09:08 AM
Put the engine bay reinforcing bar in the opposite side and it will fit easier in a book chassis.
thwang - 7/9/08 at 10:57 AM
thanks guys
chrisg - 7/9/08 at 04:27 PM
Haynes Roadster!
cheers
Chris
thwang - 11/9/08 at 08:21 PM
hi guys n gals
thanks for all the replys and thanks chrisg i,ve just ordered the haynes roadster manuels since its more for the sierra.
simon
chrisg - 11/9/08 at 08:44 PM
Thanks mate, I hope you enjoy it!
Chris
