is there a reason some of the chassis tubes are made from 3/4" RHS instead of 1"?
I have loads of 1" and if I can use that instead of having to buy more 3/4 stuff i'd rather save the money. Locost and all that!
I've got loads of round tube too!
If you are using a BMW V8, use lots and lots of 1", don't bother with the 3/4", triangulate everything including your triangulation
Originally posted by Mark Allanson
If you are using a BMW V8, use lots and lots of 1", don't bother with the 3/4", triangulate everything including your triangulation![]()
BMW V8 Locost short vid
Simon
When you have done all that - add some reinforcement!
If you build it right, that's going to be totally mental by the way![]()
] engine with LOADS of triangulation
