Guys
How do you know which springs are for the front and which the are for the rear in the springs that MK provide, they are not marked so I have no
idea
thanks
James
bigger number to the front
Are you sure its not written (painted) on one end?
Just looked under the spring one has a number 8.5 200 and the other box has 8.5 and 300, they were hidden well.
J
So use the 200's on the front as a atat point
Ok, the guy above says use the bigger number at the front though..
He's building an Indy BLADE? No?
IF ITS INBOARD SHOCKS THEN THE LIGHT ONES WILL BE THE FRONT.
Rang MK and they say heaviest (300) on the frront.
J
Search the many posts re 300lb springs being too heavy for the front on a MK Bec
