Anyone on here know of place that will make me some with a 4 x 114.3 PCD and hub dia of 66.1 mm ?
Obviously I could buy some standard ones and then get them re-drilled and maybe make a very slim hub sleeve but I'd prefer if they were made to
suit whilst still in the chuck that turned them. Might also want a bit extra meat to the OD of the hub face.
James
[Edited on 10/2/17 by Jeffers_S13]
Is it worth checking out P100 hubs , I know the have a different PCD?
Hi spec make cortina hubs am sure they would make some to your requirements. Only problem is they are a complete pain in the arse to deal with.
I think Rally Design do some blank alloy hubs for the Cortina which can be drilled within reason to any pcd
Hi . Just re-drill new pdc in the space between originals. Then turn sum spacers for middle.
Simples
Cortina P100 has 5 stud flanges + 5 hole discs (P100 solid Granada vented) the discs were hard to buy at the time, Sierra P100 discs invariably offered by motor factors.
