You have probably seen I am trying to find some tube to make my suspension wishbone eye tubes from (wanted section).
I am I right in thinking that 16G 1 3/8 OD ERW tube equates to 34mm OD with a 2mm wall thickness ?
because I just found this
http://www.merlinmotorsport.co.uk/SHEETS-AND-TUBING-Steel-Tube/c321_327/p4441/ERW-TUBE-16G-1-3/8%22-O.D.-(MTR)/product_info.html
nope...16g is about 1.6mm
1 3/8" = 34.95mm diameter. 16 SWG is 1.63mm ID is therefore 31.69mm
Thanks, I'll get the hang of these imperial measurements... eventually
