for sale aluminium fuel tank,
it supposed to fit haynes roadster but turned out to be 10mm bigger and I can't squeeze it in
dimensions are 170-190 x 260 x 610
2mm 1050 ali thickness, two internal baffles, 8mm pickup and return on the bottom, 50mm filler neck and 6mm vent on top
5 hole pattern for this cheap universal fuel sender from ebay
filler neck is on the left side
£80 with shipping
very interested - give me 40 mins to get over to the workshop and measure up?
Looks spot on - could you just give depth of the "sump" (it will be right over my diff) and height of the filler neck (I can easily shorten this so not so important) please?
Hello is the tank still for sale? Thks you
I think it'll fit, but I need to measure up again a bit more carefully.
It'll take up all of the space in the back of my Indy, but might work.
When you say £80 and shipping, do you mean £80 plus the shipping cost?
Do you know what shipping would be roughly to Staffordshire? Are you in Poland, as per your profile?
Ad
already sold!
received yesterday - many thanks
