hi all, anybody got a 2.0 pinto head, sitting around they with to part with?
please get in touch.
I,ve got a Pinto head, but not sure if its the 2.0ltr head ( how can i tell the difference?)
If its suitable , its available.
cheers
andy
hi, i am not sure how you tell the difference.
does it look like this
stuart
The head isn,t at home , so i,ll check it first thing in the morning, if you U2U me a phone number I,ll get in touch with info of the head.
cheers
andy
Measure the valves 42 in 36 ex i belive for the 2.0L
If you can measure fluid in upturned chamber, should be 48cc for a 2.0L
what you looking for stuart.
standard or modded..
I have a very lively 2.0 head...
has big valves and has had port work done on it...
from memory its a Burtons stage 3 head, but would need to measure the valve's to confirm
no cam fitted.
been gathering dust for a few years now.
[Edited on 18/10/10 by gavin174]
I have a ported 2 litre pinto head, big valve, with kent cam and vernier pulley, complete ready to go. Just came on to advertise it, but will wait on
your reply first.
[Edited on 18/10/10 by Jomibo]
sorry for late info.
I,ve got the info from the head,
I,ll type it up in another post.
cheers
andy
cheers andy,
u2u everybody as well
stu
The inlet valves are 32mm
exhaust valves 42mm
on the corner of the head is the marking "2C"
inside the head(under the cam is the following
84 shm6090d8
92
dn
clock type face 17891c2345 with flat head type screw head pointing between the 7&2
on the camshaft...76mm=6250AA
the cam has the Ford insignia on it.
also got a spare Piper camshaft, never used.
hope the info helps.
cheers
andy
Originally posted by Stuart_B
cheers andy,
stu
cheers andy.
does anybody know what if this is a 2.0 pinto head, as i can not find the value sizes to match up with them?
cheers
stuart
I think its in the Burtons catalogue.
If not should be in haynes manual.
Sorry can't be more help working in cold/dark scotland tonight.
been looking, on line says "Standard valves are 42mm inlet and 36mm exhaust"
