As above needed thought id ask on here before i buy one of the bay.
Anyone have anything?
Thanks Adam
[Edited on 21/2/11 by ahunt]
they are totally different starters the pinto and CVH what are you ftting too, the zetec uses the CVH starter as does the 1.8CVH engine
As said there differant but the pinto could be used with a spacer.
I am using a pinto starter on my zetec,as Wasa says
a 14mm spacer and bobs your uncle.
The difference in Pinto and CVH starter is just the length of the nose and starter gear throw.
Ahhh ok thanks for the info. I'm after the pinto starter then! Need it for the type 9 bolted to the zetec.
Thanks again!
Think the 8v twin cam starter fits the type9 too zetec
BUT i may be wrong
Jacko is right,the twin cam starter fits straight on but is harder to find.
Pretty sure I've got a spare pinto one, £20 posted if I can find it?
Rich
i have got a pinto one if rich hasn't
Sorted thank youuu
