Chuffed with progress!
sucksqueezebangblow - 15/10/08 at 12:38 PM
Since the original post I've added a new photo below of flatshifter bracket. Relocates shift cable further back to allow room for flatshifter sensor between flappy paddles and shift cable.
Flatshifter Bracket
Flatshifter Bracket
Original post;
Thought I'd take a moment in the lunch break to post a few progress pictures. Tried to keep it to bits you might find interesting!
Build Showing own design dry sump tank to clear steering link.
Prog 1 DS
Prog 1 DS
Cooling and mock up dash/scuttle.
Prog 2 CS
Prog 2 CS
Mods to flappy paddle system. Removed gear cable mount (to later fit Flatshifter sensor) and welded digital dash mounting in place.
Prog 3 DM
Prog 3 DM
Digital Dash incorporating warning lights in place.
Prog 4 D
Prog 4 D
And mock up dash with switch lights and four warning lights on.
Chuffed to bits. Build is coming on a pace!
[Edited on 16/1/09 by sucksqueezebangblow]
02GF74 - 15/10/08 at 12:42 PM
marvellous.
you certainly like your warning lamps; is there a manual to explain what they all mean!
tomgregory2000 - 15/10/08 at 12:43 PM
looking nice, i wish mine looked that good
tommy
thunderace - 15/10/08 at 12:44 PM
very nice
sucksqueezebangblow - 15/10/08 at 12:46 PM
Originally posted by 02GF74
marvellous.
Green LED is neutral. Three high intensity LEDs are Oil pressure warning (Manual will say HIT STOP SWITCH NOW)
Mr Whippy - 15/10/08 at 12:49 PM
ooohhh very nice, like the dash lights too
nitram38 - 15/10/08 at 12:55 PM
Very nice build!
maartenromijn - 15/10/08 at 12:59 PM
Super!
stuart_g - 15/10/08 at 01:47 PM
That looks an excellent neat build I like the digi dash mounted there.
Dangle_kt - 15/10/08 at 03:02 PM
Love the rad, what is it?
sucksqueezebangblow - 15/10/08 at 03:16 PM
I'm not sure, it is a racing rad supplied by MNR. Perhaps Marc or Chris will visit this thread and tell us. I fabricated the fan mounting brackets from anodised aluminium extrusion.
donut - 15/10/08 at 03:23 PM
Wow, that chassis looks very nice.
Johneturbo - 15/10/08 at 04:11 PM
looking good Clive, i did wonder how you were getting on with it.
should see you on the road early next year
bassett - 15/10/08 at 05:07 PM
Wow looks very nice. Are those the savage switches? if they are, are the indicator buttons warning lights or actual switches to operate the indicators.
Adam
sucksqueezebangblow - 15/10/08 at 06:35 PM
Adam
They're Savage switches. I bought blank switches and then got the inserts when I met the guy that makes them at the Autosport International Show. Going again next year 'cause I need a rain light insert and a stop switch insert.
The warning lights are on the bottom of the digital dash except for the four 10mm LEDs in the photo'.
bassett - 15/10/08 at 08:46 PM
Cheers, thought id never seen the switches as actually indicator buttons. Dont suppose youve got the guys details you could u2u me as i need some mocked up, if not no worries.
Adam
sucksqueezebangblow - 16/10/08 at 01:22 PM
Adam
Hi Adam, I'm trying to get into contact with him re the rain light and STOP insert I need so I will ask about the L&R indicator inserts you need as well if I can track him down. The number I had did not get through to him. I'll let you know if I succeed. If not I'll have to wait for the show in Jan or Feb.
Gergely - 17/10/08 at 05:10 AM
Very nice build! Keep them pics coming!
finlay - 17/10/08 at 05:21 PM
looking Ace Clive, that is some rad, very impressive
sucksqueezebangblow - 5/11/08 at 01:53 PM
Hi All,
Thank you for your great comments. I'll certainly post more pics as I make (slow) progress.
Bassett, I managed to find out that the part numbers for the indicator switches are;
SW3029 Indicator warning switch <->
SW3034 Individual arrow switch >
You should be able to ask any stockist to order them for you if they don't have them in stock. You'll need 2 off of SW3034 Individual arrow switch >
Gergely - 5/11/08 at 02:11 PM
Clive, just a question: Are you sure that you are going to be able to reach the buttons on the dash?
We were originally thinking of putting them on the dashboard as well, but it seems that when strapped in properly, it will be just out of reach, or uncomfortable to reach, so we will place them on the centre tunnel, leaving only the warning lights on the dash.
I have to say though that we need to try everything for size once the seats are finally in, the steering is properly in place, etc. But the trial fitting says the steering wheel is pretty far from the driver, the dash being further still, the buttons could prove an uncomfortable reach...
Just a thought...
And as for the indicator buttons. We have the two plain buttons, do I understand correctly that we can order the inserts only to replace the plain ones and the part No. is SW3034?
Gergely
chockymonster - 5/11/08 at 02:41 PM
Just a thought...
Gergely
That's why I went away from having a load of buttons on the dash and moving to rocker switches.
Also having the indicators there I found was difficult to change direction signs on roundabouts etc. It took me ages to work away around that and I eventually settled on the signaldynamics self canceling indicator system which is a dream to wire in. Makes the hazards really easy to wire up.
sucksqueezebangblow - 6/11/08 at 11:27 AM
Yes, your right, that's why I mocked up the dash. The switches end up at finger tip distance and will be an uncomfortable strech with harnesses fully tight, as on the race track. On the road with the harnesses slightly looser they will be just about okay (being tall I have long arms). It would certainly be handy if MNR design a switch pod for the dash to bring them a few inches closer. I'll think about knocking something up in the mean time.
I've fitted a 60mm OMP steering wheel spacer to bring the steering wheel to a comfortable distance, so next job is to design a spacer for the flappy paddle system.
The product code is for the complete switch. I don't think they do the inserts separately (except at shows).
Just a thought...
Gergely
sucksqueezebangblow - 11/11/08 at 10:03 AM
Great news, I just got a message from the manufacturers that they may be putting a Savage STOP switch into production! I'll post more details when/if I get them.
marc n - 14/11/08 at 08:37 PM
looking good so far clive
best regards
marc
sucksqueezebangblow - 21/12/08 at 09:53 PM
I've added a picture of the bracket I've welded up and fitted behind the steering column bearing mount. This relocates the shift cable further back in order to fit the flatshifter sensor between it and the flappy padles.
Flatshifter Bracket
Flatshifter Bracket
THe new Flatshifter manual states thet the sensor must be at the gearbox end of the shift cable. So since posting the above picture I've reloated the bracket to the right of the wheel towards the driver and removed the sensor.
[Edited on 1/2/09 by sucksqueezebangblow]
jambo - 22/12/08 at 01:08 AM
wots a flatshifter?
is it changing gear at full throttle?
sucksqueezebangblow - 22/12/08 at 09:23 AM
Originally posted by jambo
wots a flatshifter?
Thats right, with a shifter you get full throttle clutchless up-shifts and , if you get the right model, clutchless down-shifts. Take a look at; Flatshifter link
sucksqueezebangblow - 12/1/09 at 01:51 PM
Adam
Hi Gergely,
I did the Autosport Show last Sunday and visited the Trilogy stand. Unfortunately Andy, the chap that usually helps out with the inserts, wasn't at the show. I did speak to his brother Ian and left details of the inserts we are after. He said he would pass the request on and see what he could do so keep your fingers crossed.
Bassett, I think you wanted complete switches so hopefully the order codes helped you out?
yours, Clive
[Edited on 12/1/09 by sucksqueezebangblow]
richardh - 12/1/09 at 07:13 PM
looks superb
bassett - 13/1/09 at 10:51 AM
Hi, well i ordered through MNR as they do the switches now and had another order to place with them so they may may not come with them but hopefully i could just use some stickers but thanks for the help and may be something i get back to after sva
cheers
Adam
sucksqueezebangblow - 14/1/09 at 02:08 PM
cheers
Adam
Ian reckoned Andy will be at Stonleigh so if you still need inserts then I'll try again there.
sucksqueezebangblow - 19/1/09 at 10:02 AM
Bassett, Gergely,
I got a call from Andy at Trilogy this morning. He got me the "STOP" and rain (shower head & water symbol) switches. He's also going to get the four indicator arrow switch inserts you need. It'll be a few weeks but I'll let you know when they arrive.
bassett - 19/1/09 at 12:07 PM
Ours arrived from MNR over the weekend and the indicators now have the arrow direction signs rather than being blank - just need to wire them in now.
Adam
sucksqueezebangblow - 26/1/09 at 12:32 PM
Gergely,
Trilogy posted the Savage switches and inserts today including a pair of indicator inserts for you.
Do you still need them and if so where would you like them sent?
jacko - 26/1/09 at 07:29 PM
Do you have a light to show low brake fluid / hand brake ?
Gergely - 27/1/09 at 09:24 AM
Hi, no thanks, we originally toyed with the idea, but have eventually decided to put two small micro switches on the steering wheel and create indicator electronics under the dash. It will be push once for 3 flashes, or push for 0,5 sec for constant flashing indicator, another press of either button will cancel it.
We got the idea from Chockymonster and a friend will create the electronics.
Cheers anyway!
Gergely
sucksqueezebangblow - 27/1/09 at 10:09 AM
Cheers anyway!
Gergely
No problem, they arrived today and they were the wrong ones anyway! (dual arrow instead of single arrow).
If anyone on the forum wants them just let me know. They are the Savage inserts only (not the switch just the symbol insert). I have two, each has two arrows pointing left and right. They are the symbol you would use as indicator warning light (as opposed to indicator switch). They're free to a good home.
sucksqueezebangblow - 27/1/09 at 02:36 PM
Hi Jacko,
Sorry for the delay, I missed your post somehow. Yes I do have a brake/handbrake warning light on the digital dash (comes as part of the dash). If you need one I think there is a Savage switch which can be used which has the warning symbol on it (they double up as warning lights). You should be able to get one from a Savage stockist or MNR.
