I'm building a cat with an injected pinto. I'll need to install a catalytic converter for belgian emission tests. Apparently there were
closed loop 'catalysed' pinto versions in germany in 1987/1988. So there must have been original Ford ECU's for this setup. Does anyone
have a reference to these ECU's? I would assume that by swapping in any of these (or is it just a software upgrade??), I obtain a workable
solution.
tia
