Flush fitting numberplate lamps?
RazMan - 13/12/05 at 09:10 PM
I am looking for a flush fitting numberplate lamp (maybe a pair if appropriate)
It needs to go above a conventional UK plate in a horizontal surface.
Can anyone offer any pointers? I can't seem to find any with the usual suspects
dave dickson - 13/12/05 at 09:50 PM
Have a word at your local caravan dealer.
The rear numberplate lamps on a Bailey Senator are rectangular things about 3 or 4 inches long and maybe 1 inch wide. They sit in the horizontal panel above the recessed number plate, and sit proud of the suface by a few mm in a rubber seal.
RazMan - 13/12/05 at 10:17 PM
Sounds ideal! I'll have a sculk around the local travellers site then
omega 24 v6 - 13/12/05 at 10:24 PM
V/hall astras carltons/omegas estates all have recessed light in the tailgate handle. I might even have a pair lying in the shed but it'llbe the weekend before I can check/photo them for you. If I have a pair you can have them for the postage.
RazMan - 13/12/05 at 10:31 PM
Jolly decent of you old chap!
andyps - 13/12/05 at 10:40 PM
Rover 800 number plate lamps are flush fitting. Loads in scrap yards.
02GF74 - 14/12/05 at 10:54 AM
I don't understand what you mean by a flush fitting lamp - is the number plate recessed? It has to be otherwsie if the lamp is flush and the 'plate is on the same surface, it cannot possibly be illumintated. Just curious.
RazMan - 14/12/05 at 12:31 PM
Sorry about being so vague - the plate is indeed recessed and the lamp will be mounted in the recess 'wall' above the plate. So if the lamp sticks out more than a few mm it will obscure the plate itself hence the need for flush mounting.
02GF74 - 14/12/05 at 01:52 PM
ok; that makes sense. volvo 850 estate have two lamps in the rear tailgate handle that sine linght onto a recessed plate.
A trip to the local scarpyard should prove to be a good source - can't imagine there is much demand for such items.
tks - 15/12/05 at 09:34 PM
Willing to pay for postage and some more if needed...
i have no idea what to do anyway with the license plate of the car...
anyway i need the item in the drawing if we need the same or someone has one laying arround i'm willing to buy it..
RazMan - 15/12/05 at 10:30 PM
tks - By the look of your drawing you just need a classic surface mounted Lucas style lamp like
