Just thought you might enjoy this…
my other half runs a shop in Southampton, And people are constantly peeing up against the back door which makes everything stink. I put in a CCTV
camera but most people seem to ignore it, so I put a water pipe above the door to spray people and attached it to a solenoid valve and a sensor.
You can watch the results here...... Raspberry Pi VS People urinating in public https://youtu.be/bO6F7upH0bQ
a raspberry pee is overkill for this, I would have just used an old ir motion detector (recycled from a security light maybe even leave the light working...). but at least auto flush now works
I thought of that, but the motion sensor won’t email me video clips for my amusement :-)
Hahaha, brilliant. Any chance you can move the pipe outlet to further away from the door and increase the delay on the timer.. should net you better
results I recon. Once people are 'started ' it will take them a bit longer to get away and they will also have to go out through the
waterfall.. this is purely hypothetical off course.. Just engineering optimisation.... id'e never condone such actions....
Increase the delay for sure and get a better nozzle so it sprays out more.
Wonderful work.
ace
Spot on
[Edited on 15/6/20 by ian locostzx9rc2]
Very funny, but I would rig the setup to a tank of your collected pee, as that would be VERY FUNNY !
Excellent!
Nice work and seems to be moving the people on before they even get started
I would also put up some face pics on the wall, name and shame
Slightly more delay required.
Bet delivery driver love though.
Fab - you might want to blur faces in case someone gets upperty.
Only caution is i'm sure some a*rs could will try to claim assault so definately don't use anything other than tap water
Could you share the details - are you using motioneye?
Most excellent!!!
A delay would be ideal and the water actually cleans the area!
I was asleep in my van years ago once outside a pub (long story) and a bloke started peeing up the front grill. I waited until he got going and then
full beams and twin airhorns at the same time. He literally wet himself, I thought he might try and fill me in but he ran off soaking wet!
I would be tempted to use a powerful mist spray - nowhere near damaging, but very wetting.
Brilliant! Much better than any other solution I have seen to the paper hats who think that everywhere is their toilet - should be installed at every site of problems!!!
Now, if those down pipes were metal, and a little bit of current was flowing down them, it would be only a small jolt,
but they would wee themselves
Or as in the medieval days, of pouring boiling hot oil down from the turrets, but but very hot pee and pink die, ?
My last one is very boring,
VERY big signs, saying that anyone caught doing something not appropriate is being filmed and will be forward to the police, and every pub/club around
the area
Nah forget it, I would go with a delay of 7 seconds, and then a complete sploosh, at least 5 gallons of piss
Awesome
Haha love it! Perfect tune for it too
Is thea a Thomas crapper invention a flushing toilet or your idea .
change the water for diesel and that would spoil there night
[Edited on 18/6/20 by jacko]
Thanks for the comments, It needs some adjusting I know, in the mean time here’s Episode 7......
Episode 7
LUV IT !!!
The bloke in the sandals hahahahahaha
have you thought about putting an urinal on the wall, fitted to the drain ?
