Evening all
Can anyone recommend me the jet size for my pinto zx9r conversion?
It's a 2.1 by the way.
I did bike carbs on a zetec
Mines on 1.8mm and its running great
I know pintos are a bit more thirsty
What i did was buy a modellers drill bit kit, drilled them out to 1.6-tried it , then 1.7 etc till i got it right
I then bought a set of jets in the size ide drilled them to give as good a spray pattern as poss
Theyre weber dgav jets so less than a tenner for all 4
This was the easiest way without buying loads of jets
Well worth the faffing imo , transformed the car
most folk seem to start around 1.6mm and see how it goes from there
I think that's whats in mine, bogg bros did them for me as there best first guess to get the engine running with a trip to there rollers planned
for when the cars on the road
Most model drills can be way out ...
Always use a vernier - measure them them for their true size.
Thanks for the advice.
I'll have to have a play around and go from there. I'm going to have it set up on rollers anyway.
150pc Precision Mini Micro Drill Bits, Suitable For Craft, Model, Hobby, Etc
They vary in accuracy - need to measure them before use ..
[Edited on 19/11/14 by johnemms]
