Miks15
| posted on 28/3/09 at 03:26 PM |
Pedal Box : Help
I have cut up all the pieces for my pedal box now but i'm a little but unsure asto how much room i should be leaving to allow the pedals to move
back and forth freely but not side to side.
I have some nylon bushes that will be a push fit into my pedals. Then an M10 bolt through the middle.
Do i need washers between the pedal and the mounting holes to give a nice clean pivot?
Also should the bush be flush with the tube welded on the pedal or should there be a slight be sticking out so that it doesnt start pivoting on the
tube instead of the bush?
Mikkel
wozsher
| posted on 28/3/09 at 08:18 PM |
In some ways you have answered the question yourself
either make the bushes 1-2mm longer than the tube or fit a tube inside the bush
1-2mm longer than the bush and use a smaller bot
