New Topic New Reply
Author: Subject: Chasis? are they available to order
technics
posted on 14/5/09 at 08:22 PM Reply With Quote
Hi there Great site All. Im thinking of starting a locost project and just wondering if theres anyone out there who makes the chasis. I am a qualified mechanic but welding isnt my strong skill, cutting to the chase im looking at trying the volvo t5 engine on a bmw box will the chasis take this and do i have to use ford parts ie diff, shafts, wishbones, uprights, hubs
mark chandler
posted on 14/5/09 at 08:41 PM Reply With Quote
No reason not to use all the mechanics off the donor really, they all match.
stevegough
posted on 14/5/09 at 08:50 PM Reply With Quote
Hello, Technics and welcome to Locost!
You are in great company here, lots of help and useful info available.
You can purchase the chassis only (if that is all you want to start with from nearly all the kit car manufacturers - there are also individual members who will be happy to make you a chassis probably much cheaper.
I know of one guy who put a T4 volvo in a seven roadster - but it wasn't the easiest conversion. Write a u2u email to him - his user id is.... matt_claydon.
I am not a mechanic - just an enthusiastic (or obsessed!) ameteur and I am not sure about the running gear question, but I'm sure someone else will be along shortly who will help.
Good luck - and kit car mags + shows are also a starting point for a new project. The next show is at Newark 20/21st june weekend.
Regards, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
AdamR
posted on 14/5/09 at 09:01 PM Reply With Quote
The short answer is yes, there are plenty of possibilities for buying a chassis ready made.
But the chassis really needs to be built around your engine, gearbox and running gear choices. As you're planning something unusual it'd be worth it a hundred times over to get yourself on a welding course to learn some fabrication skills, so that you can build your own chassis. Even if you can buy the perfect chassis for your engine, there are so many brackets etc that need to be made as you go a long. I really can't imagine tackling a project like that without a welder, TBH!
Hope that helps. And good luck!
RK
posted on 14/5/09 at 10:37 PM Reply With Quote
Take it from someone (a non-mechanic, with not a lot of enthusiasm right now) whose build had EVERYHING go wrong at one point or another (even a wheel got stuck on), and don't use those parts. Use the ones hundreds of other people have used: Zetec, Vauxhall etc. Please just believe me when I say that your life is made 1000 X easier when it's been done a lot before. Reinvention of the wheel is best for those with A) unlimited funds B) unlimited space C) unlimited time and D) lots and lots of knowledge. And patience.
If you don't mind a 5 year project, well go ahead then!
mr henderson
posted on 15/5/09 at 07:02 AM Reply With Quote
d'accord
Benzine
posted on 15/5/09 at 08:51 AM Reply With Quote
Borrrrrring You only live once and it's better to fail at originality than succeed in imitation. Just dae it! \m/ >.< \m/
RK
posted on 15/5/09 at 01:40 PM Reply With Quote
While you're at it, I'm sure you can use an old 40 gallon oil drum and get someone to the moon too. Everything is POSSIBLE.
technics
posted on 15/5/09 at 04:28 PM Reply With Quote
Chassis Roadster
well thanks for the positive answers guys, not mentioning names for negativity. Thinking about the roadster build i want to really go with the T5 engine but i dont want a fully complete chassis im looking for something thats near completion with out brackets etc i just want a square and tru chassis frame work in roadster format. This will be so i can get on my way in a sense and get a clearer path layed out, that way it wont be so difficult if i prepare and weigh things up before commiting
mr henderson
posted on 15/5/09 at 04:41 PM Reply With Quote
I note your comments about negativity, but I still think RK is right. He is in a good position to know just what it is you are thinking of undertaking.
If you choose to go a more conventional route there will still be lots of room for individual solutions to the multitude of problems that arise. You might still be able to squeeze the T5 engine into a book chassis, but I'm pretty sure you will need to redo the gearbox tunnel area.
As far as the other compnents are concerned, especially the front and rear suspension, then you really are better off sticking to Ford compnents
John
technics
posted on 15/5/09 at 04:54 PM Reply With Quote
i am well aware problems will arise, im willing and confident enough i feel to be able to get around them but just looking for info on the matter before i go guns blazing and come up a cropper. can you tell me what the best literature i can find on different chassis. And do companys still cater for larger chassis ie body panels nose cones............Hell i put a 406 2.0 turbo engine into a 205 gti once that was no easy task
Volvorsport
posted on 15/5/09 at 05:24 PM Reply With Quote
whatever running gear you choose , youll end up modifying things as they go along .
your major question is wether you want a live axle or IRS .
www.dbsmotorsport.co.uk
getting dirty under a bus
mr henderson
posted on 15/5/09 at 05:55 PM Reply With Quote
Buy the book
http://www.haynes.co.uk/webapp/wcs/stores/servlet/BookFeature_BYOSportsCarView?new=Y&storeId=10001&catalogId=10001
You might be able to book the older, Ron Champion book second hand, the chassis is a little bit smaller than the one above. Or you can download updated plans for it from
http://mcsorley.net/locost/
Fromk these you should be able to work out the size of the engine compartment. Most manufacturers' engine compartments will be similar sizes apart from the Luego Viento
John
New Topic New Reply
