hamza
posted on 4/6/10 at 06:39 PM |
rectangular sections
I have purchased Chris Gibs book, I live in Peshawar Pakistan, the 51x25 mm rectangular section as recomended in the book is not available can I use
50x25 instead.
In addition can you please tell me how much of the 25x25, 19x19 and 50x25 mm rectangular sections are required respectively as the same is not
provided in the book
Sincerely
Hamza
RichardK
| posted on 4/6/10 at 06:55 PM |
I would say that using box thats 1mm bigger won't be a problem at all or you could tack 2 of the 25mm together!
Rich
Gallery updated 11/01/2011
dan_g8
| posted on 4/6/10 at 06:57 PM |
as above, most people weld 2 bits of 25x25 box together.
also have you had a look on haynes forum?
http://www.haynes.co.uk/forums/index.php
[Edited on 4/6/10 by dan_g8]
smart51
| posted on 4/6/10 at 07:03 PM |
I would use 50 x 25 in place of 51 x 25 without a second thought. If that 1mm made all the difference then both are too small.
Alan B
| posted on 4/6/10 at 07:09 PM |
Never heard of 51 x 25, pretty sure it does not exist.......I'll bet it's 2" x 1"
50.8mm rounded to 51 and 25.4mm rounded to 25
50 x 25 will be fine.
Chippy
| posted on 4/6/10 at 10:48 PM |
I think you will find it's just a typo, and should be 50 x 25 anyway as it weld to 25 x 25. I think the only reason it's there is so the
back panel can be fitted easily. HTH Ray
hamza
| posted on 5/6/10 at 02:25 PM |
Thankyou
Dear All,
Thanks to all of you for your valuable input and suggestions, will be getting back to you with more queries as I progress
Sincerely
Hamza
