smart51
| posted on 3/6/11 at 12:59 PM |
Can you laser cut square tube?
I've made a chassis brace for my car, which works nicely, but there's lots of fiddly cutting and welding. Members of the owners club want
me to make some for them, so I was thinking, can you get RHS tube laser cut? It would save me a job, since someone else is paying.
blakep82
| posted on 3/6/11 at 01:07 PM |
pretty sure waterjet can, andyw7de's got a little cabinet in his place full of stuff he's cut in half. mobile phones and their chargers
for example, a perfect clean cut the whole way through.
laser might be able to, but i don't know how it would do when it gets to the vertical side of the tube
________________________
Minicooper
| posted on 3/6/11 at 01:31 PM |
You certainly can but you need one of these or something similiar, I've seen tube done on a conventional laser by accurate placement on a guide
plate which is then cut normally, only works in one plane really and if the cutting stays away from edges
http://www.youtube.com/watch?v=UeGVbtrrHjE
blakep82
| posted on 3/6/11 at 01:51 PM |
i want one! lol, would be awesome for doing the fish mouths on tubes if building loads of chassis, like for business or something
smart51
| posted on 3/6/11 at 02:34 PM |
You have no idea how much I want that machine. Given how that one worked, I guess the laser wouldn't cut through top and bottom in one sweep.
Volvorsport
| posted on 3/6/11 at 05:10 PM |
laser disperses after the cut , ive cut t45 tube for malcolm wilson in past life .
im pretty sure you can do square tube , but the torch head would need to move up and down with the workpiece as it rotates , which would probably
mean a dedicated tube laser , not just a laser with a tube cutting attatchment .
www.dbsmotorsport.co.uk
getting dirty under a bus
beagley
| posted on 3/6/11 at 07:04 PM |
No kidding! You could make some very intricate joints with something like that. Being a diabetic I wonder if I could sell my pancreas for one of
those, it doesn't work anyway....
I'm not scared!!! I'm just marking my territory.
compositepro
| posted on 3/6/11 at 09:06 PM |
why use square tube on a tube cutting laser the joints can be mitred perfectly ....so you can use round tube ....hence its as easy to use round as
square tube now...simples
smart51
| posted on 3/6/11 at 09:47 PM |
So water jet is the way to go then.
Mad Dave
| posted on 4/6/11 at 08:11 AM |
http://www.youtube.com/watch?v=UeGVbtrrHjE Cheers David
Road Runner Racing's SR2 has it's chassis and wishbone tubes laser cut just like this. It's is quite expensive for a single
chassis/wishbone set so you have to order in batches to reduce the cost per set. The chassis build time time is reduced significantly as each tube
just drops into the jig straight out of the box from the laser cutters
Dave
