New Topic New Reply
Author: Subject: floor rivit size and type
bart
posted on 29/11/14 at 06:54 PM Reply With Quote
hi all
I am at the stage when I need to rivet the alloy floor to the frame
? what to use
I intend to use 1.5 mm half hard aluminium sheet and 4mm c/s aluminium pop rivet's with silicon sealant between.
any comment's would I be better using large head rivet's ? or steel rivet's ect
any advice welcome.
big_wasa
posted on 29/11/14 at 06:58 PM Reply With Quote
You don't want silicone but the proper PU sealant like sikaflex or tiger seal, floor and rivets sound fine.
bart
posted on 29/11/14 at 07:06 PM Reply With Quote
aluminium rivit
should I be using steel rivet's or aluminium
or aluminium outer / steel inner
big_wasa
posted on 29/11/14 at 08:13 PM Reply With Quote
I used 4mm closed end aluminium. Get plenty of pu in the holes to help prevent galvanic corrosion.
This combo will NEVER come of. You only really need a few rivets on the corners to prevent peel the Pu is that good it sticks like s###t to a blanket
In fact you could go down a size to 3.2mm with your little car and save a few grams.
bart
posted on 29/11/14 at 09:10 PM Reply With Quote
little
its not "LITTLE" it just looks small in the mirror !!!
my feelings are hurt now !!
New Topic New Reply
