Nickp
posted on 22/9/15 at 06:00 AM |
Rivnut material?
I'm looking to get some M6 rivnuts and a suitable tool for fastening bodywork, interior panels, brackets etc onto my steel chassis.
What are the pros and cons of the various materials?
Aluminium? For- Easy to use, cheap? Against- Weak threads, react with steel chassis?
Steel? For- Cheap, Strong? Against- Rust?
Stainless? For- Strong, no rust/reaction? Against- Cost, harder to use?
Are these correct or am I missing something?
Thanks in advance,
Nick
adithorp
posted on 22/9/15 at 06:37 AM |
I'd use steel. Quality ones are coated to reduce corrosion. The ones holding my undertrays get plenty of weather and show no signs of rusting. I
always use the splined ones as they grip better and the plain shanked ones can work lose and spin in the chassis.
http://jpsc.org.uk/forum/
907
posted on 22/9/15 at 06:54 AM |
Buy the tool from Memfast.
It won't matter which rivets you buy or what they are made of as the tool does them all with ease.
Paul G
[Edited on 22/9/15 by 907]
coyoteboy
posted on 22/9/15 at 07:26 AM |
Personally I'd always use stainless, just because I hate rust and wouldn't trust myself not to overtorque an aluminium one!
Nickp
posted on 22/9/15 at 07:36 AM |
Ta guys,
Anyone for aluminium, so we'll have the full set?
40inches
posted on 22/9/15 at 07:46 AM |
quote: Originally posted by Nickp
Ta guys,
Unless fixing to an aluminium panel, no! Steel all the way.
rdodger
posted on 22/9/15 at 07:47 AM |
I used steel ones into the chassis and aluminium ones into aluminium.
I also used rivstuds into the chassis for earth points and a couple of mounts.
Memfast tool is fantastic and well worth the money.
MBrown
posted on 9/10/15 at 02:41 PM |
I have tried 2 different rivnut tools, one the memfast tool and another one. Neither one worked well at all so I made my own which is a slight
alteration to the nut and bolt idea.
The explanation for it can be found here:
Rivnut tool
Hope that helps! Don't waste your money!
[Edited on 9/10/15 by MBrown]
[Edited on 10/10/15 by MBrown]
loggyboy
posted on 9/10/15 at 03:00 PM |
I used ally - for no other reason as that's what came with the tools (laser)
None have been hard to install (except one I mess up trying to use tool at angle due to lack of access).
But cars not on road yet so cant report long term issues.
Mistral Motorsport
