flyingfuji
posted on 20/9/05 at 11:51 AM |
Virgin Builder Enquiry
Hi, Guy's Three new builders here aged 14, 16 and 40! Gues it's the old yin thats providing the cash! Anyway, just about ready to go and
cut the steel for the chassis...bog standard, just as in the book.
Looking at various sites there are sporadic mentions of errors or irregularities with the chassis details in the latest version (February 2004) which
I appear to have. I am now at the metal buying stage and really need assurance that all is correct in the book. Are there any problems with the book
contents? I know Gremlins are all to eager to do their work at the printers, but are there any errors builders should be aware of?
Thanks chaps, in anticipation of some good answers.
Hellfire
posted on 20/9/05 at 11:57 AM |
Can't answer your questions about the chassis but there are loads on here that will.
May we be the first to welcome you to the Madhouse.
Good luck with the build
TimC
posted on 20/9/05 at 12:02 PM |
And I thought you were building a virgin..
How dissapointing!
Russ-Turner
posted on 20/9/05 at 01:39 PM |
Tubes FU1 and FU2 will give you a bit of hassle. Best to think a few tubes ahead. One thing i only did half way through was paint all of said tubes in
red oxide, then used the grinder to clean it off where i was going to weld it. Good luck mate.
kb58
posted on 20/9/05 at 01:51 PM |
You need to read more before jumping in!
Reading is cheap, buying or building the wrong stuff isn't. Do a search here for "McSorley"; he has corrected drawings and you
should use his instead of the book's.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
James
posted on 20/9/05 at 03:57 PM |
Agreed!
Get the http://www.mcsorley.net plans or else you're a fool!
Leave out FU1/2 till last as they'll need moving a load.
And make sure you make a jig for your chassis brackets (See my photo archive). Use this also to place FU1/2 accurately.
Also, read up on the LA/LB assembly at the front as it could do with being changed so you can better place your suspension brackets without
bracing.
Hope that helps, but please read through the archives!
James
- Muhammad Ali
Mix
posted on 21/9/05 at 06:16 AM |
I agree, download the McSorley plans, but use them in conjunction with the book.
The main book errors as far as the basic chassis goes are in the position of the FU tubes and the trailing arm attachments. There are other errors
which have crept in when the imperial measurements were converted to metric so check before you cut.
The main area where McSorley will not help is in the castor angle of the front uprights and the associated placing of the brackets, as suggested
above, search that one out on here. Also have a look at Cymtrik's chassis stiffening mods, you may wish to incorporate some of them.
I am really enjoying building my chassis but strongly reccomend you do a bit more reading on here before you get too far into the build.
That said theres no reason not to buy the basic chassis material and start slowly.
Cheers Mick
flyingfuji
posted on 21/9/05 at 09:15 AM |
Building Virgins Part 2
Thanks lads, I'll hold off until I've done a bit of reading and I'll try to source some plans then. I'll let you know how the
disaster unfolds.
paul v6
posted on 21/9/05 at 09:57 AM |
Hi Guys, I'm at the planning stages so still reading everything I can find regarding chassis mods, I understand Cymtrik has made changes
which have greatly improved chassis stiffness but I cant find any drawings or specific details of what he has done??
Can anyone point me in the right direction?
Many thanks
Paul
Mix
posted on 21/9/05 at 11:33 AM |
Search under user name cymtriks
Mick
Gav
posted on 21/9/05 at 12:18 PM |
http://locost7.info/mirror/mirror.php
their is a .doc file in their somewhere, the document he produced, good reading.
Alan B
posted on 22/9/05 at 08:58 PM |
Many thanks
Paul
Cymtrik's mods are theoretical unless someone has followed them and proven their value.
I'm not saying they aren't good mods as they seem to make sense, just saying they aren't proven, unlike the Austraian mods which are
well tested.
posted on 22/9/05 at 11:09 PM |
I built my car before I was on the internet and used the book but altered to fit a Sierra engine and gearbox. Whatever mistakes are in the book will
leap out and hit you in the face if you have any common sense at all. There are enough standard chassis running round to illustrate that they
don't need much in the way of stiffening if you are in the U.K. If you are so unsure you may be better off buying a chassis form a tried and
tested supplier. You will most likely alter bits as you go along anyway, just get in there.
