New Topic New Reply
Author: Subject: Poly bushes
MikeRJ
posted on 16/5/03 at 09:11 PM Reply With Quote
Poly bushes
My newly acquired Avon/locost hybrid chassis has some nasty looking metalastic type bushes in the wishbones. They don't fit the inside of the 1" tubing very well, so I was hoping to get some poly bushes, preferably with a "top hat" shape so the bush protrudes either side of the tube. Can anyone recommend a supplier for these? The tubes on my wishbones are approximately 37mm long.
Viper
posted on 16/5/03 at 09:24 PM Reply With Quote
what is the id of the tube where the bushes will go?
MikeRJ
posted on 16/5/03 at 10:05 PM Reply With Quote
Good point. Don't have my calipers handy, but it looks to be pretty much exactly 21mm or 8/10"
Hornet
posted on 17/5/03 at 08:04 AM Reply With Quote
I would say that your tubes are probably too small in inner dia to accomodate pu bushes.
You need enough room for a bolt.. say 12mm and a crush tube say 17mm outer dia. or there abouts. This will leave a very small wall thickness on your pu bushes and they would either fail or not last very long.
Only my opinion though..
MikeRJ
posted on 17/5/03 at 11:55 AM Reply With Quote
Currently using M10 bolts. The book only seems to use M8 so should be plenty strong enough?
If the tubes are too small, I'm happy to chop them off and weld larger ones on, as I have to remake the front wishbones anyway.
Viper
posted on 17/5/03 at 12:14 PM Reply With Quote
If you are going to replace the tubes then Luego do polybushes that are cheap, thats where i bought mine.
MikeRJ
posted on 17/5/03 at 12:59 PM Reply With Quote
Thanks for all your help. Just ordered a set from Luego who have been extremely helpfull.
New Topic New Reply
