Tinks
posted on 30/1/07 at 04:47 PM |
Polo Rad fixing screws
I have tried looking for other threads but not found any on this..... Can someone advise me of the screw type and size that is used to fasten the
bracket to the Polo VW302 radiator.... is it a plastic selt tapper...?
Thanks in advance
John
pewe
posted on 30/1/07 at 05:15 PM |
Tinks, I used ordinary zinc plated self-tappers but make sure they are blind ended or cut the points off - just to make sure they don't go too
far!
Cheers, Pewe
flak monkey
posted on 30/1/07 at 05:17 PM |
I tapped the holes M6 as they are a 5mm hole anyway. Fine if not done up too tight.
Sera
http://www.motosera.com
Marlon
posted on 30/1/07 at 05:21 PM |
as above without the tap, I just wound in m6 bolts, It went in quite easy.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
rayward
posted on 30/1/07 at 05:27 PM |
tapped M6 and screwed M6 studs in with threadlock
on
Ray
Surrey Dave
posted on 30/1/07 at 06:20 PM |
Length?
Tapped holes to 6mm and cut bolts to suit , if they are too long they will bottom out and probably break through.
the_fbi
posted on 30/1/07 at 07:50 PM |
There is a Merc A class airfilter mount which is a double ended M6 with an antivibration rubber bonded between. (basically an antivibration mout) this
is what I've used. Works a treat.
Studs are the right length and you get anti-vib mounts too
Part number is on here somewhere.....
Edit:
4 x A116 988 05 11 @ £ 1.73 each + VAT.
[Edited on 30/1/07 by the_fbi]
RichardK
posted on 30/1/07 at 08:08 PM |
As above tapped to M6 and short M6 bolts used.
Rich
Gallery updated 11/01/2011
Danozeman
posted on 30/1/07 at 08:13 PM |
M6 in mine...
Dan
Simon
posted on 30/1/07 at 08:22 PM |
Used 1/4" whitworth on mine - all I had lying around
Simon
omega 24 v6
posted on 30/1/07 at 08:34 PM |
M6 for me too.
SixedUp
posted on 30/1/07 at 09:19 PM |
I had nothing the right size, so I ordered a set of the official self-tappers from VW. They had a full set for me the next morning, total cost was
something like £1.80 ...
Richard
westcost1
posted on 31/1/07 at 12:13 PM |
my rad came with the self tapers in it!
Tinks
posted on 31/1/07 at 12:34 PM |
Thanks Guys' M6 it is !!!!
