gixxerpat
posted on 28/4/07 at 05:58 PM |
Front suspension travel
How much travel should there be with the book suspension arms etc.
posted on 28/4/07 at 06:57 PM |
With dampers fitted or without?
gixxerpat
posted on 28/4/07 at 07:35 PM |
Without.....just checkin before i fit the shox
balljoints can bind easily, slight differences in angles etc can make a big difference in total travel. As little as 3" can be made to work.
What is important is that you dont bend stuff by letting it run into the limits.
gixxerpat
posted on 28/4/07 at 07:39 PM |
yeah, i know its the bj's that limit the travel , just looking for a measurement to get me started. Would 2" upward travel with the car on
the ground be enough do you think.
posted on 28/4/07 at 08:01 PM |
hard to call really, its borderline ok. You would go in knowing you have 2" to play with, pick a spring, then work out which bumps to avoid or
slowdown for. 2" should be just fine to manage bumpy roads, however a pothole or raised manhole might bottom you out. Engine weight is also
important.
I would balance it up against how hard it would be to modify to get more travel.
Anything will bottom out somewhere! Ive had my van hit the bumpstops!
[Edited on 28/4/07 by JoelP]
gixxerpat
posted on 28/4/07 at 08:15 PM |
I thought if i went by the book there should be a definate measurement thats common to all....the only mods i've made is im using sierra
uprights.
t.j.
posted on 30/4/07 at 08:02 AM |
If you don't mount the springs I noticed the upper ball-joint is the limit.
You don't want a broken ball-joint, so mount your coil as limiter.
