oadamo
posted on 30/10/07 at 08:18 PM |
peddle mounts
hi ive started making some alloy floor mounted peddles for my locost. but how do you fix the cables to them. and where about do you fix the cables.
will i need a steel bush to stop them from wearing where the fixing go. ive seen some mounted to the box section on the floor is this the best or
sould i make them in there own box that bolts in.
adam
worX
posted on 30/10/07 at 11:40 PM |
Why have you chosen to make them in Ali Adam?
What is the thickness of the Ali pedal shaft/stem?
oadamo
posted on 31/10/07 at 08:08 PM |
good question i dont no lol. they will look good whn done lol. the stems are 6mm and the peddle bit is 4mm and the boss is 25mm.
adam
Bluemoon
posted on 1/11/07 at 08:58 AM |
I would not make em from ali.. The Mk brake pedal stem is of the order 4 to 6mm steel (can't remember exactly). Using Ali is not going to give
as much strength, and if you can make em strong enough they will probably crack as they age (unless designed with sufficent margin)..
Dan
kb58
posted on 1/11/07 at 01:17 PM |
Aluminum is fine as long as it's "thick enough", whatever that is. As a guide, the Tilton unit I have uses 1/2" (12mm) cast
aluminum for the pivot/balance bar housing.
Do the math and you'll find that in a panic stop, there can be nearly 1000lbs force on the mounting points. Not someplace to be cutting corners.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
