New Topic New Reply
Author: Subject: Welding small angles
speedyxjs
posted on 24/2/08 at 08:26 AM Reply With Quote
Whats the technique for welding the small angles on the chassis?
richard
posted on 24/2/08 at 09:30 AM Reply With Quote
yes there are a few tight ones to weld up.i made sure i had a tack both sides and then weld half each sides inturn but knowing i would end up with a widder fillet.To me it was a case of making sure it was weleded rather than worry about having a widder fillet as it will not be seen most of the time anyway.
twybrow
I am a relative newb, so am happy to be corrected, but I believe you want to turn up the wire speed to ensure it gets into the corner.
bonzoronnie
posted on 24/2/08 at 09:36 AM Reply With Quote
Do you mean the welding of very tight corners ?
If you do.
It may help to do some of the follwing.
Ensure you have about 5mm of tip showing from the end of the torch shroud.
Ensure you have about 5mm of wire sticking out from the tip.
You will be able to gain further access if you take a spare shroud. Then crush it lightly in a vice to flatten it a little.
Remember not to crush it so much it touches the tip.
Up the welding current a bit and use the vertical down method of welding if possible.
This method takes a little bit of practice to perfect but produces a very tidy weld.
Very important. Make sure you are using the correct size tip for you wire. It'll wander about if you dont !!??
I hope this makes some sense.
Ronnie
[Edited on 24/2/08 by bonzoronnie]
posted on 24/2/08 at 11:41 AM Reply With Quote
In a tight angle you can get away with more stick-length (ie protruding wire). Normally you can only use so much length before you lose the gas shield. But a tight angle naturally keeps the shield better.......
Mansfield
posted on 24/2/08 at 01:11 PM Reply With Quote
It has been discussed on here before but I cant find it. I like the idea of making a gusset out of the same sized box section and welding that in instead, easier to weld and maybe stronger too.
EDIT - found it, have a look at 907's sketch in his reply. If it is really tight angle you could make the gusset from 2"x1".
http://locostbuilders.co.uk/viewthread.php?tid=43345
[Edited on 24/2/08 by Mansfield]
speedyxjs
posted on 24/2/08 at 02:12 PM Reply With Quote
Cheers for the replys. That thread is a big help
[Edited on 24-2-08 by speedyxjs]
New Topic New Reply
