New Topic New Reply
Author: Subject: Lolocost /Robin Hood
JohnFol
posted on 16/7/02 at 11:43 PM Reply With Quote
Just got a few bits delivered from them, including a bush set. This includes outer / inner tubes as well as the rubber inserts. Now the daft question.
Am I right in saying that the bush makes contact with the sides of the suspension mounts (ie the c shaped bits about 2" across) ?
As opposed to the inner tube? Does this mean the rubber needs lubrication?
interestedparty
posted on 17/7/02 at 07:09 AM Reply With Quote
The suspension movement is supposed to be provided by the bush material itself flexing, and therefore no lubrication is required. This is the reason why suspension bolts should only be tightened with the car in normal level position.
John
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
JohnFol
posted on 17/7/02 at 09:03 AM Reply With Quote
Thanks for the reply ..
New Topic New Reply
