New Topic New Reply
Author: Subject: OT - but chassis related
posted on 13/8/09 at 12:32 PM Reply With Quote
what would be the advantage of the 'S' shaped down tube on this bike?
Surely strongest and lightest is a stright tube.
Frame is Specialized carbon fibre.
paul the 6th
posted on 13/8/09 at 12:41 PM Reply With Quote
less chance of the front wheel hitting the s-tube so you could have longer travel suspension maybe?
Could just be an aesthetic thing maybe?
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
Mr Whippy
posted on 13/8/09 at 12:42 PM Reply With Quote
there's a bike just like that at the other end of my office, used I believe to cycle to work on a tarmac pavement…
A lot of it I suspect is just down to styling and being different, rather than correct engineering practice.
tegwin
posted on 13/8/09 at 12:44 PM Reply With Quote
Stlying... and also I assume it allows the shock somewhere level to bolt to....
Nice bike
www.verticalhorizonsmedia.tv
Staple balls
posted on 13/8/09 at 12:45 PM Reply With Quote
Pictures a bit small, but if it's CF, I imagine it's at least partly to shape it around the lower crown on the fork, go arse over tit just right and you can do a lot of damage to a frame that's not made out of plastic.
Also, looks modern and fast.
blakep82
i think its just to look cool
for some reason i'm thinking its more important that the top one is straight, but i don't know why i think that... maybe if it is a little less strong, perhaps that extra little flex dampens out any bumps a bit better?
________________________
maartenromijn
posted on 13/8/09 at 01:49 PM Reply With Quote
I believe it is the strongest in CF to laminate the main tube all in once, to avoid a less strong joint at the cranks. To do so, I think they came up with this refreshing S-tube.
[Edited on 13/8/09 by maartenromijn]
BLOG: http://thunderroad-super7.blogspot.com/
New Topic New Reply
