New Topic New Reply
Author: Subject: headlight mount diameter
luke
posted on 25/8/09 at 09:54 AM Reply With Quote
I'm just at my dads work now making up my rear trailing arms and found a length of large diameter tubing which may be suitable for the headlight mounts but I don't have my book with me to check what size is needed.
Does anyone know that diameter of that tube that the headlights bolt through? Or have a diagram of the headlight mounts for the standard chassis?
Cheers!
handyandy
posted on 25/8/09 at 10:20 AM Reply With Quote
i,m building the haynes roadster & the headlamp bracket is 45mm steel tube that the headlamp mounting bolt goes thru,
if that helps.
andy
luke
posted on 25/8/09 at 10:24 AM Reply With Quote
Brilliant! Thanks!
Unfortunatly this stuff is 60mm. Damn.
Only 45 he has is a 4mm wall thickness! Bit over engineered there I think!
Ill keep hunting!
handyandy
posted on 25/8/09 at 10:27 AM Reply With Quote
unless you fit mega large headlights
no prob, glad to have helped.
andy
luke
posted on 25/8/09 at 10:30 AM Reply With Quote
I got given a set of brand new headlights, and they have trumpet things on the bolts that clamp onto the mount. But as I'm not at home I can't measure them!
New Topic New Reply
