Miks15
posted on 25/5/10 at 05:51 PM |
closed rivnuts?
Hi guys,
Is using closed end rivnuts a must when putting them in the chassis? I thought this is what is best to do, but i cant seem to find them anywhere.
Also what material rivnuts are best to get?
Ally stainless or mild steel?
Mikkel
turbodisplay
posted on 25/5/10 at 05:55 PM |
What about thread lock? Water will still get through the outside if no sealant is used anyway.
also use the same material as you are fitting to ie ali - ali steel - steel to prevent galvanic corrosion.
Darren
[Edited on 25/5/10 by turbodisplay]
clairetoo
posted on 25/5/10 at 05:57 PM |
I've got a bag of closed end rivnuts at work - I think they are M6 - not sure if they are steel or ally though .
Any use ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
Miks15
posted on 25/5/10 at 06:05 PM |
Cheers Darren,
Cheers Claire you have a U2U
indykid
posted on 25/5/10 at 11:56 PM |
ally are easy to set but will corrode for fun if they get wet often.
steel are a little bit harder to set but FAR more robust
