rodgling
| posted on 3/6/10 at 02:49 PM |
Roll bar bolts
I'm about to attach my roll bar and am wondering about bolts. The kit I'm using supplies 12 M8 class 8.8 bolts, but I have bought some M8
class 12.9 bolts - is it sensible to use the highest grade available, or are there other factors to consider that make 8.8 a better choice?
| posted on 3/6/10 at 02:57 PM |
12.9 every time in my book. 8.8s are cheaper. The only other advantage of 8.8s are a wider range of bolts available. But if you can swap a 8.8 bolt
for an identical 12.9 one then I would every time.
| posted on 3/6/10 at 03:25 PM |
One question...what is the roll bar bolted to?
Most bolt on roll bars I've seen are bolted into rivnuts, which IMO would fail long before an 8.8 bolt.
Danozeman
| posted on 3/6/10 at 03:26 PM |
As nick says whats it bolting to? Theres no point putting decent bolts in if it bolts to sod all.
Dan
flak monkey
| posted on 3/6/10 at 03:29 PM |
Theres no point in fitting one if it bolts to sod all....
Sera
http://www.motosera.com
snakebelly
| posted on 3/6/10 at 03:45 PM |
have to say i have never seen a roll bar bolted into rivnuts, you would have to be nuts to even consider that!
rodgling
| posted on 3/6/10 at 04:00 PM |
It bots through four substantial (i got through several drill bits drilling the holes) steel plates welded onto the chassis, so I think that aspect is
fine. No rivnuts I'm happy to say :-)
LBMEFM
| posted on 3/6/10 at 09:20 PM |
I would also say it does need struts to brace it.
sdh2903
| posted on 3/6/10 at 09:53 PM |
Took mine up to M10 12.9 spec, just didnt think that the M8's looked beefy enough.
Maybe a bit overkill but not a bad thing with a roll bar!
iank
| posted on 4/6/10 at 07:42 AM |
Not completely true. When they finally overstress 12.9 snap 8.8 bend. That can make the difference between losing a wheel/the front brakes so
suspension shouldn't use stronger than 8.8. For a roll cage it shouldn't matter though.
This is the same reason crane hooks aren't made of high carbon steel, you want them to start straightening rather than snapping like a
carrot.
[Edited on 4/6/10 by iank]
Anonymous
rodgling
| posted on 4/6/10 at 10:10 AM |
hmm, that sounds like a strong argument for using 8.8 - I wouldn't want them snapping off in a crash. I'm confused...
