New Topic New Reply
Author: Subject: MX5 Engine positioning
Tshort1984
posted on 8/8/13 at 08:28 AM Reply With Quote
Morning all.
Hope someone can help me out. Firstly, I apologise if this is in the wrong section.
I am installing a 1.8 Eunos MX5 engine and gearbox into the chassis this weekend, but I don't have any bodywork to check the positioning.
I have looked around the forum, and cant seem to find an answer, so am I right in assuming the following:
1) The imaginary line along the spark plug holes should be central in the chassis (left to right as viewed standing at the front of the car looking towards the rear)
2)The engine should be as far to the rear of the engine bay as possible, less about 30mm
3) the height of the engine is set so that the bottom of the higher base of the sump is flush with the bottom of the chassis rails, leaving the lower part of the sump around 40mm below the chassis.
Is it easier to install the engine/gearbox as a complete unit, or is it easier to split them first?
Thanks in advance!
pewe
posted on 8/8/13 at 02:07 PM Reply With Quote
Not familiar with putting one into a Se7en but genarally I'd be surprised if the engine wasn't centred side to side.
Front to back position surely dictated by the length of the drive-train i.e. engine, gearbox, prop shaft and rear axle - unless you are using a custom length propshaft?
Engine height again dictated by available height under the bonnet. - 40mm sounds reasonable for the sump to be exposed underneath but the less exposed under the chassis the less there is to bash on speed bumps.
If inserting the engine and gearbox together it sometimes helps to jack up the rear end e.g. put it on ramps, thus increasing the height available for sliding it in - an engine crane is a good idea for this.
Maybe you should have a look/enquire on the Haynes forum?
HTH.
Cheers, Pewe10
Slimy38
posted on 8/8/13 at 02:56 PM Reply With Quote
I was advised that the propshaft needs to be custom length, so I wouldn't worry too much about getting the whole drivetrain in place. I was working off the premise that I want the gearstick in the best position and use that for fore and aft location. This also means that I would leave the engine and box connected while fitting?
With regards to side to side, I did think that it's the propshaft that needs to be centred? Although in all likelyhood the propshaft is already in line with the spark plugs anyway.
rdodger
posted on 8/8/13 at 03:46 PM Reply With Quote
Have you got the steering column in?
I positioned mine centrally. Set it back as far as poss leaving the gearstick in the best position for me. I just sat in the chassis on a cushion and set it from there.
I set the engine as low as possible with the bump of the sump below the chassis rail and the bell housing flush with the bottom of the rail. Then I chopped the sump level with the bellhousing and got it welded up.
Slimy38
posted on 8/8/13 at 04:43 PM Reply With Quote
Originally posted by rdodger
I set the engine as low as possible with the bump of the sump below the chassis rail and the bell housing flush with the bottom of the rail. .
Did mounting it low have any impact on the height of the gearstick?
Smoking Frog
posted on 10/8/13 at 07:43 PM Reply With Quote
If you're using the mx5 diff I think this is offset. The gearbox should be inline horizontally or vertically and also perpendicularly with the diff and if one plane is offset it should be no than 3 to 5 degrees. If your diff is offset and the engine central it make sense to make the height of the gearbox the same as the diff (but still must be perpendicular, so can't tilt the engine). Bare in mind I'm no expert and it's what I've read elsewhere.
Slimy38
posted on 10/8/13 at 08:41 PM Reply With Quote
As far as I can tell (and I'm also no expert) the diff itself is offset, but the propshaft face still ends up in the middle of the car. The two driveshafts are slightly different lengths, at least on some cars.
I'm not welding up my diff mounts until I have the diff and the driveshafts out of the donor, just in case I have an offset diff.
Smoking Frog
posted on 11/8/13 at 12:10 PM Reply With Quote
Depending on the position of the clutch master cylinder, clearance can be a problem between clutch fork. You may have to fit a concentric slave cylinder.
Slimy38
posted on 11/8/13 at 02:27 PM Reply With Quote
Probably better for me to ask on an MX5 forum, but do you know if the MX5 clutch can be converted to a cable clutch?
rdodger
posted on 11/8/13 at 02:50 PM Reply With Quote
I guess it is a little lower but is still plenty high enough. About the same as in the MX5.
[img][/img]
The diff is offset with different length drive shafts.
I guess the easiest way to sort this is to fit it central and use 2 short or long shafts?
Phil @ Talon does a fabricated diff housing to get over the issues difficulty of mounting the diff.
[Edited on 11/8/13 by rdodger]
Talon Motorsport
posted on 11/8/13 at 03:06 PM Reply With Quote
It surprises me that nobody thinks to cut and shut the gear stick to put the end of it where you want it rather than move the engine and box as a whole.
Smoking Frog
posted on 11/8/13 at 03:15 PM Reply With Quote
Sorry don't know. Try the engine in with slave and master cylinder fitted, depending on the engines position it may not be a issue.
rdodger
posted on 11/8/13 at 03:38 PM Reply With Quote
I think people do Phil.
On the MX5 the stick is bonded onto a short stump. It can be removed and something welded on.
In my case I got the engine as far back in the chassis as possible which put the stick in the perfect position.
I did have to modify the drivers foot well for the clutch are though.
[img][/im g]
New Topic New Reply
