FuryRebuild
posted on 22/8/13 at 11:35 PM |
Fury Duratec sump clearance
Hi All
I was measuring up tonight and have managed to make myself paranoid. I have 70mm between the bottom of the chassis rail and the bottom of the sump.
Can anyone with a fury let me know what sort of range they have between chassis rail and sump bottom. I'm fairly sure that will give me adequate
ground clearance, but if i have to chop engine mounts, now is the time.
M
www.furyrebuild.co.uk
snapper
posted on 23/8/13 at 03:52 AM |
More important is bottom of sump to ground when fully loaded
I eat to survive
I drink to forget
FuryRebuild
posted on 23/8/13 at 12:05 PM |
Of course, but until I get the car off the lifts and onto the ground, I don't have much of a datum to the floor to work with.
I'm fairly sure it's about 1" further off the ground than my pinto, but on a stock fury knowing what sump to chassis rail setup
someone has will give me some reassurance.
I have the opportunity to recut the engine mounts and gain about an inch, but I would rather keep the COG as low as possible.
big-vee-twin
posted on 23/8/13 at 05:50 PM |
I have a 7 but clearance below sump above ground is 110mm.
http://www.triangleltd.com
FuryRebuild
posted on 23/8/13 at 07:29 PM |
Thanks - seems like I got it right. It was so long since I did this work that I got to second-guessing myself last night.
scudderfish
posted on 23/8/13 at 07:34 PM |
My Fury has an underslung exhaust made of random bits of pipe held together by a multitude of clamps. At its lowest point I have a ground clearance
on 37mm. I try to avoid speed bumps.
