New Topic New Reply
Author: Subject: Chassis Protection During Build
43655
posted on 16/6/14 at 06:22 PM Reply With Quote
Hi guys,
Where I'm working on my project is a barn on the side of a hill, in Wales.
This is very much a recipe for windy and damp, and naturally all my metalwork is rusting up
What would be recommended for protecting the steel stock and chassis while i'm working on it, and while it's stored?
Naturally when it's don't i'll be properly painting it with Epoxy Mastic probably
My thoughts so far are:
Primer -
would take a lot of it, not sure how well it protects against water either.
then sand off the areas to be welded as and when
Oil coat
got lots of old engine oil there
kinda yuck to work with though
clear off with white spirit or similar before welding etc
Or any other ideas?
DIY Si
posted on 16/6/14 at 08:22 PM Reply With Quote
I use tins of a spray etch primer from Ebay. Seems to do well on stuff in my garage, but it sounds like your place is going to be tougher on metal. It's worth a go over oily metal, as it needs less cleaning before welding/painting etc. I think the formula has changed on the stuff I use though, as the latest stuff doesn't weld through quite so cleanly.
Sun Tzu, The Art of War
43655
posted on 18/6/14 at 05:06 PM Reply With Quote
primer looks most likely, but not sure how well it protects against moisture? doesn't primer absorb water a little?
Hopefully won't be bad over summer while i'm building, suppose over winter i could give it the final coat, then sand back any parts to be worked on again. bit poo though
Always clean back to bare metal on welding areas, but the oily stock is a bit unpleasant to handle
jacko
posted on 18/6/14 at 05:16 PM Reply With Quote
Primer in not waterproof only the gloss is
jacko
Slimy38
posted on 18/6/14 at 07:33 PM Reply With Quote
Mine isn't quite that exposed, but i am letting the surface go a little rusty. The main reason is because most good primers seem to sit better on rough metal (por15 being an obvious example). Whenever i weld i give it a good scrub with a wire brush but otherwise just leave it. It does also give me the encouragement to get the chassis complete before i end up with a car thats more 'barn find' than lotus rep!
43655
posted on 20/6/14 at 07:14 PM Reply With Quote
ha ha
so what about using cheap top coat?
Not very good with paint stuff, but just regular aerosol paint stuff
should be primed first i suspect
might as well just use Epoxy Mastic in the first place
New Topic New Reply
