New Topic New Reply
Author: Subject: beginner welding question...
lowgman
posted on 27/3/06 at 07:26 PM Reply With Quote
Hi everyone,
I finally decided to build a locost recently and just started to cut and weld up my book sized chassis. I have a few questions about welding up the chassis.
I've done some welding a few years ago, just exhaust piping with a mig welder. This would be the first time I would be doing such a large welding project.
I picked up a Miller Challenger 172 MIG welder, which works great, but I have a few questions:
1. I did quite a few practice welds on scrap box section for a few days before beginning on the frame. I came up to the conclusion that upping the power level and slowing down the wire helped penetration, as did the swith to a thinner wire. However, I managed to blow a few holes on the chassis bottom rails. One of them was rather large (maybe 5-6mm). What would be the largest hole I can fill with a mig weld?
2. After my last welding session, I went to shut off my welder and noticed that the gas gauge showed the tank was empty! I have no idea how long I've been welding without gas, but I did notice that there was a tiny bit more splatter than usual (I thought I was just getting sloppy
) Should I be worried and cut those welds out and lay on a new bead? Other than the splatter, the base weld (for a lack of a better term) looks just as good as the first few welds where I knew the gas was on.
3. There was also a slight warpage to the chassis after I was done with the welding. I would say that the front end has about 1mm of warpage (enough to slide 2-3 sheets of copy paper under the front) Should I be concerned about this?
4. For the T joints and L joints in the frame rails. Should I be laying down more than one bead?
I will try to post up some pics later on this week.
Thanks in advance!
posted on 27/3/06 at 07:32 PM Reply With Quote
the weld would probably be visibly porus (damned spelling...!) if there was no gas at all. A mm of warpage is better than most id guess, i had more like 10mm on my first one (fortunately scrapped now!). You can fill very large holes if required, but its not great. You end up with a hot blob in the end, which might weaken the overall weld. I wouldnt worry myself, as im sure that practice will make it a rare thing.
As for point 4, i dont get ya
kb58
posted on 27/3/06 at 07:42 PM Reply With Quote
My guess is the tank wasn't *really* empty yet. I ran out of gas completely one time TIG welding and brother, you'll know it when it happens. Smoke, sparks, and welds that look like a sponge are all symptoms of no gas.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
lowgman
posted on 27/3/06 at 07:44 PM Reply With Quote
Thanks JoelP!
Sorry, my welding terms aren't up to par yet
THis is what i meant:
Should I "layer" the welds on these type of joints?
welderman
posted on 27/3/06 at 08:12 PM Reply With Quote
A single fillet weld should you mate, your not welding thick stuff so should be ok. Just don't grind the welds flush to make them look good.
Thank's, Joe
I don't stalk people
antonyg
posted on 27/3/06 at 08:48 PM Reply With Quote
Hi, if you want some info on welding try asking these guys on this site, full of experienced welders
http://www.ukwelder.com/
Antony
New Topic New Reply
