Pablo
posted on 23/12/01 at 10:31 PM |
Rear Track Size?
Anyone know the rear track size for the Escort and the Sierra as Im trying to work out if the Sierra will fit without modifying the chassis width,
most of the pics of peoples cars tend to have a few inches under the rear arches to spare and got me thinking it might fit under there, I dont fancy
extra wide arches so I would have to widen the seating area if I cant do it.
Pablo
ChrisW
| posted on 24/12/01 at 06:36 PM |
My Escort RS2000 axle is (from memory) 1200mm between each drum backplate. Not sure about Sierra width (and remember it's IRS not live axle) but if
you look in the photos section under Stoneleigh 2001 there is a shot of a Sierra steering rack in the Locost chassis which looks far too wide.
If you want extra width try a Capri axle - it is approx 100mm wider than an Escort mk2 equivalent.
Chris
Pablo
| posted on 24/12/01 at 09:16 PM |
Ah cheers Chris, if you are right then the Sierra being 1260mm will in my reckoning sill fit under the rear arches without modification to the
chassis.
Pabs
ChrisW
| posted on 24/12/01 at 09:25 PM |
Don't go on these as gospel! As I said, they're both approximates!
Take it you're going IRS if you're using Sierra stuff? In which case it should all fit anyway because most (if not all) the IRS Locost kits you can
buy use Sierra diff and half shafts.
Chris
Pablo
| posted on 24/12/01 at 09:34 PM |
yeah Chris but I was wanting to get away without modifying the width, therefore I can carry on and build my chassis without any worries. After
checking the appropriate Haymes manual of course
Have you got a Escort rear axle?
Pablo
Pablo
| posted on 24/12/01 at 09:45 PM |
Doh of course u got 1, any chance u could measure it 4 me? please I would rather someone measure it than try to find it in the haynes manuals if its
even in there.
Pablo
ChrisW
| posted on 25/12/01 at 06:48 PM |
Yeah, I have an mk2 escort RS2000 axle. As I said, from memory, it is 1200mm from the back of the drums. I will measure it again to check next time
I'm out there but I'm 95% sure that's right.
Chris
Dunc
| posted on 25/12/01 at 10:02 PM |
Hey guys,
I've been away from it for a bit and missed the gossip. (Chris hope you got the inserts ok) From the Haynes manual the track for the sierra is 1453
for the front, 1468 for the rear. I believe this is the measurement from wheel centre to wheel centre.
I took some notes from the first sierra I stripped and noted that the diff is off centre at the rear and the right drive shaft is approx 30mm longer
as a result. Working back from individual measurements of piece parts the distance between the brake shields is 1420mm. I got another sierra last week
with a 2.0 DOHC in it so I'll measure the distance to confirm in the next couple of days.
Dunc.
Pablo
| posted on 25/12/01 at 11:35 PM |
Thanks guys.
Pablo
jcduroc
| posted on 21/2/03 at 03:45 PM |
Sierra rear axle
quote: Originally posted by Dunc
From the Haynes manual the track for the sierra is 1453 for the front, 1468 for the rear. I believe this is the measurement from wheel centre to wheel
centre.
Working back from individual measurements of piece parts the distance between the brake shields is 1420mm. ...
Dunc.
Pablo
The distance between Sierra drum flanges (where wheels contact to) is 1530 mm.
Track will depend on the wheels offset.
Joćo Matoso
Rorty
| posted on 22/2/03 at 02:18 AM |
I hope I'm not speaking out of turn, but that's the approach I'd take if I were to build a Locost.
1/ Look at axle widths (wheel flange to wheel flange).
2/ Choose which wheels to use to give correct track/clearance.
BTW, track is measured at the tyre centres, not the wheel centres. They differ, depending on wheel offset.
Cheers, Rorty.
jcduroc
| posted on 26/2/03 at 09:53 PM |
quote: Originally posted by Rorty
... track is measured at the tyre centres, not the wheel centres. They differ, depending on wheel offset.
Rorty
What do yoy mean by "Wheel centre"?
Joćo
Rorty
| posted on 27/2/03 at 04:28 AM |
Joao:
Sorry, I should have made that a bit clearer. When I refered to wheel centre, I meant the metal disc in the wheel's centre (with the stud holes in
it), which is what I understood Dunc to mean when he was talking about the Sierra's track width of 1468, a few messages back.
I've noticed others refer to the track being the width of the axle (hub face to hub face), which is obviously the same as the (inside) wheel
centre(disc), which lead to my outcry!
I'm on some pretty funky medication at the moment, so please excuse me if I boldly state the bloody obvious!
Cheers, Rorty.
jcduroc
| posted on 2/5/03 at 09:53 PM |
Sierra rear axle track width
wheel centre. ... Working back from individual measurements of piece parts the distance between the brake shields is 1420mm. I got another sierra last
week with a 2.0 DOHC in it so I'll measure the distance to confirm in the next couple of days.
Dunc.
Dunc
Where in the Hayes manual did you find the rear track width?
Track is the distance from the centre contact point of the tire to the opposite one.
Did you measure the other one?
Joćo Matoso
