New Topic New Reply
Author: Subject: 19mm pipe bends
morfy
posted on 13/11/06 at 07:37 PM Reply With Quote
19mm pipe bends
hi all
need some help about the pipe that needs to be bent
1st is there any builders in or around portsmouth
if not
2nd what methods have been used to stop if from kinking
thanks
NeilP
posted on 13/11/06 at 07:43 PM Reply With Quote
Pack it tight with sand...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
3GEComponents
posted on 13/11/06 at 08:03 PM Reply With Quote
You should be fine with a set of plumbers tube benders, they support both inside and outside of the tube, might take a bit of elbow grease mind
big_wasa
posted on 13/11/06 at 08:21 PM Reply With Quote
By some scrap bends, cut and weld
emsfactory
posted on 13/11/06 at 09:28 PM Reply With Quote
Buy a pipe bender?
John Bonnett
posted on 14/11/06 at 09:19 AM Reply With Quote
Be careful to discriminate between tube and pipe. Tube is thinwall and cannot be bent using a pipe bender. Pipe such as waterpipe has a much thicker wall and may be bent with a hydraulic bender using the appropriate formers.
Tube may be bent in a variety of ways most of which were covered in depth if you search on this site for "Bending Tubes".
John
New Topic New Reply
