New Topic New Reply
Author: Subject: spring rate?
jambo
posted on 27/2/07 at 03:01 PM Reply With Quote
spring rate?
hello, does any ony know a formula for working out a spring rate for a coilover in a vertical position
ecosse
posted on 27/2/07 at 03:13 PM Reply With Quote
Have a look at THIS thread.
Alex
kb58
posted on 27/2/07 at 03:51 PM Reply With Quote
Stand on the spring, measure how much it compresses, rate = lbs(kg) / in(cm)
Being a "coil-over" spring has nothing to do with it, however, when you measure it, take the spring off the shock, else the stiction will give a wrong value.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
jambo
posted on 27/2/07 at 03:58 PM Reply With Quote
sorry lads my question is not clear,i know how to measure the value of a spring what i want to work out is what spring weight to give the correct ride using say the weight of the car etc.
Tralfaz
posted on 27/2/07 at 08:03 PM Reply With Quote
All sorts of variables in play there.....
FWIW I am aiming for a 1:1 motion ratio on my coilovers with the spring rate equal to the corner weight.
On my BEC I am guessing....
500lbs on Front 'Axle' (All up w/driver) - 250lb springs.
Brian
kb58
posted on 27/2/07 at 09:30 PM Reply With Quote
Define "correct". Therein lies the problem; it's a personal decision. If you want a *general* guideline, make the wheel rate 1/2 the unsprung weight.
New Topic New Reply
