deanwilson
posted on 8/8/07 at 07:34 PM |
bending the chassis
has any one thought of bending parts of the chassis rather than cut the angle and weld it
mookaloid
posted on 8/8/07 at 07:35 PM |
Yes - Robin Hood
mookaloid
posted on 8/8/07 at 07:37 PM |
Actually I think most of the main manufacturers bend at least some of the parts
big_wasa
posted on 8/8/07 at 07:45 PM |
Yeh lots but most people dont have the bending equipment to do it
mark chandler
posted on 8/8/07 at 07:50 PM |
A bent chassis is a pre crashed one !
Imagine a triangle and how rigid it is, now put a bend on one side and its lost its strength, it will quickly collapse if loaded up.
If you want curves then retrict these to the body panels or you will weaken the car.
Regards Mark
JohnN
posted on 8/8/07 at 08:04 PM |
Bends are at the corners, not along the sides
Richard Quinn
posted on 8/8/07 at 08:06 PM |
I wouldn't have a problem with bends instead of corners. I have yet to see a roll cage made of straight bits welded together
mark chandler
posted on 8/8/07 at 08:15 PM |
But then how many cages have you seen made of 1" 16swg tube ?
There is a reason why the MSA calls for 2" CDS tube and restricts the circumference of the bend.
Regards Mark
Volvorsport
posted on 8/8/07 at 10:10 PM |
square tube isnt much good for bending , while retaining any of its strength/stiffness , compared to a triangulated structure
round tube is much better to use .
www.dbsmotorsport.co.uk
getting dirty under a bus
locogeoff
posted on 8/8/07 at 11:38 PM |
I considered making the botton rails out of one piece of tube, not bending as such but cutting appropriate Vs out of the tube and bending and welding
closed, if you get my drift.
Ended up doing it the traditional way.
posted on 9/8/07 at 08:05 AM |
Just as well the method you describe is a no go area from the fracture mechanics and fatigue view point.
