New Topic New Reply
Author: Subject: New chassis needed
takumi
posted on 2/10/07 at 10:50 AM Reply With Quote
New chassis needed
After buying a s/h chassis off ebay, and making all the new engine and gearbox mountings.. I've discovered some very dubious welding..and the use of car body filler..
Now I'm considering ditching the chassis and buying a chassis made by a known manufacturer.
It's been usefull as a jig to get the engine /gbox mounts sorted, good job I didn't get too far into the build before the shock horror started..
Any recommendations for a chassis supplier ?
cheaper the better.
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
garage19
posted on 2/10/07 at 10:53 AM Reply With Quote
Give me a set of plans and i'll TIG you one up.
Just round the corner from you too.
takumi
posted on 2/10/07 at 10:56 AM Reply With Quote
its most appreciated..
we do seem to buy miles from anywhere in Suffolk..
Do you have a locost chassis jig?
I'm tempted to consider the +4 chassis variant.
iank
posted on 2/10/07 at 10:57 AM Reply With Quote
Body filler on a spaceframe
If I were building a true locost, i.e. book dimensions and live axle I'd talk to procomp.
Probably not the cheapest but I'd be confident about it being made properly.
Anonymous
takumi
posted on 2/10/07 at 10:59 AM Reply With Quote
I'm tempted to ask dad'io if he would want build another kit, then he can fund it.
What are MK Indy chassis' like?
locoboy
posted on 2/10/07 at 11:15 AM Reply With Quote
Severely flawed according to some..........
Made of gold according to others..........
Locoboy
takumi
posted on 2/10/07 at 11:17 AM Reply With Quote
What about the Locost +4 chassis.
Is the whole chassis +4" , or just the rear end to use the sierra diff and shafts..
takumi
posted on 2/10/07 at 11:33 AM Reply With Quote
Aries Motorsport do a locost chassis with IRS (weren't they previously a StuartTaylor chassis..?)
Is that worth considering.?
VinceGledhill
posted on 2/10/07 at 11:58 AM Reply With Quote
MK Indy chassis is spot on. IMHO
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
posted on 2/10/07 at 12:40 PM Reply With Quote
To keep the weight down.
Is it so bad that you cannot grind out the badness and reweld?
worX
posted on 2/10/07 at 01:11 PM Reply With Quote
Once it has been noticed and got to that point and your confidence is gone in the chassis, I'm not surprised that the OP would want to start again to be honest...
posted on 2/10/07 at 01:35 PM Reply With Quote
The whole chassis is +4" (and usualy an inch or so taller), which gives you lots more space in engine bay and in cockpit. Gives a much wider choice of seats.
AdamR
posted on 2/10/07 at 02:08 PM Reply With Quote
...but a much narrower choice of bodywork!
If you don't have enough confidence in your fabrication skills to strip your current chassis and fix it then a +4 might be too much work.
If I wasn't as patient and stubborn as I am I'd throw in the towel & buy an MNR!
[Edited on 2/10/07 by AdamR]
wilkingj
posted on 2/10/07 at 03:13 PM Reply With Quote
How much for the chassis you got off Ebay?
Best Regards
Geoff
http://www.v8viento.co.uk
takumi
posted on 2/10/07 at 04:55 PM Reply With Quote
Wasn't much at all, i think £87.. was a while ago now..
It's been very useful to design the engine mounts and new gearbox mount, and get the exhaust manifold completed.
I'm just anoyed at the waste of time..
I' think I'm gona stick with the traditional locost chassis,
MK still advertise a Locost kit at £995. atlest that will come with some body work, the bits I dont need I can flog..
[Edited on 2-10-07 by takumi]
chrisg
posted on 2/10/07 at 05:27 PM Reply With Quote
I'd build a Haynes Roadster myself.
But that's just me.
cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
New Topic New Reply
