Dale
| posted on 17/10/03 at 02:20 AM |
how wide is your pedal box?
Just about to weld in my tunnel and am wondering how wide the area is that you have for your feet. Maybe how wide(inside dim) size feet and if its
comfortable enough?
Dale
Hornet
| posted on 17/10/03 at 07:05 AM |
Not the exact answer you are looking for.. but relevant I hope? My tunnel is standard as per the book and there is not a lot of clearance around the
gearbox... especially the gearbox support bracket. So what I am saying is.... In my opinion it would be wrong to make the tunnel smaller than standard
unless you are using a different setup.. for example a bike engine.
Hope this helps.
Dale
| posted on 21/10/03 at 01:56 AM |
my chassis and running gear is quite different -much longer wheelbase, 2.3lturbo (similar to the xr4ti) t5 tran, and 7.5 inch rear. If I come from
the firewall at an 45deg angle and then bring the tunnel back at an angle from there I can have almost 14 inches of foot room at the pedals. I am
only worried about strenghth being I want as much stiffness as possible.
Dale
drmike54
| posted on 31/10/03 at 08:19 PM |
Turbo 4
I am building a locost with a Ford Turbo 2.3 base. Drivetrain from a Thunderbird TurboCoupe.
