<<  1    2  >>
New Topic New Reply
Author: Subject: Chassis paint
PAULD
posted on 23/12/08 at 11:06 AM Reply With Quote
chassis paint
Following Steve M's reply, a chap who restores classics recommended dulux houshold gloss over a good zinc primer, says it's as good as anything.
Miks15
posted on 23/12/08 at 12:04 PM Reply With Quote
Would something likeTHIS be suitable?
Then a household gloss on top
Or even halfords own brand zinc primer?
Just wanting to pick some up today if i can
[Edited on 23/12/08 by Miks15]
posted on 23/12/08 at 12:23 PM Reply With Quote
Originally posted by dhutch
Failing that, ive heard a lot about Por15 and an keen to have a play!
Their most useful product is Metal Ready - you squirt it onto bare steel with a hand sprayer, leave it for a few minutes, then rinse it off. I think it puts a thin phosphate coating on the metal, but the main benefit is its effect on the surface - it leaves a slightly rough, keyed finish that's perfect for paint. Untreated, degreased steel doesn't hold paint well unless it's keyed in some way.
The only down-side is that it has to be rinsed off with loads of water (it's not harmful to the environment when diluted, so no great risk when rinsed off - you will need gloves when using it neat, though).
posted on 23/12/08 at 12:30 PM Reply With Quote
The ultimate (from the looks of it!!) for chassis painting would be
POR Hardnose paint
http://www.frost.co.uk/item_Detail.asp?productID=9514
You can't build a car for £250 but you might be able to paint it for that much!!!
mad4x4
posted on 23/12/08 at 12:49 PM Reply With Quote
Stuff called ZINGA - basically cold galvi.. can be brushed or sprayed.
Www.zinga.co.uk
Scot's do it better in Kilts.
russbost
posted on 23/12/08 at 01:22 PM Reply With Quote
"Hammerite / smoothrite does not stick well to nice new shiney steel - prefers rusty metal"
& all the comments about hammerite chipping etc.
Like any paint Hammerite will only stick properly if it's got something to stick to, make sure your chassis is oil free (wash down with thinners/whte spirit) & rub down with some 180 grit, hammerite will then stick & IMHO is no more likely to chip than any other paint. Alternatively use a leght coat of acid etch after degreasing, basically anything should then be able to get a grip.
If you want something to last forever go for the epoxy based stuff that Nitram used, doesn't look particularly pretty tho'
Mr Whippy
posted on 23/12/08 at 01:53 PM Reply With Quote
Www.zinga.co.uk
I bought two cans of this stuff. Have to say I wasn't too impressed see linky
posted on 23/12/08 at 02:27 PM Reply With Quote
I used that stuff on my wishbones and rear suspension arms - I applied it with a disposable 2" foam roller, as used for gloss paint. Results in a decent finish - not as flat as spraying, but no brush marks... a bit like the finish you get when you put vinyl emulsion on a wall (an even coat, with a regular distribution of slightly bobbly bits).
posted on 23/12/08 at 08:13 PM Reply With Quote
After removing the crap powder coating from my front suspension I used an oil based primer (Don't have the can to hand so don't know what make ) followed by some paint specially made for brush painting from our local Movac paint suppliers .Paint was mixed to match the rest of the chassis , dries to a good finish and has been on for nearly a year with no lifting, chips etc . Again I can't remember the name as the tin had no markings but will try to find out . Well happy so far and will be redoing the rest of the chassis etc the same.
MikeR
posted on 24/12/08 at 10:30 PM Reply With Quote
Www.zinga.co.uk
There was a review i was reading a while ago of a cold galv paint. It compared itself to some other stuff inc Zinga. Zinga did not do well by comparison (bleeding obvious really, they wouldn't do a comparison where something else worked out better)
Trying to remember what it was now..... will post later if i do remember.
<<  1    2  >>
New Topic New Reply
