<<  1    2  >>
New Topic New Reply
Author: Subject: Fury chassis for Alfa V6
Markymark
posted on 6/7/13 at 08:18 PM Reply With Quote
A thread resurrection worthy of Lazarus
Hi thought I would update this thread, still not a lot of progress made I'm afraid.
Had a lot of building work done, including making my garage twice the size
So
Chasis comes home
Chasis comes home
Got the chassis home from my sisters garage into my new carpeted garage
Build tables
Build tables
Made some build tables
Chassis on build tables
and put it on
Floor pans drilled
Floor pans drilled
Drilled floor pans ready for fitting
Will turn it over and drill the transmission tunnel panels before I fit them though
It's so good to finally be able to start putting it together
Mark
ReMan
posted on 6/7/13 at 09:27 PM Reply With Quote
At least it's your own thread to resurrect.
Good work hope to see it running soon. Going to be easier and more rewarding with a proper space to do it in
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
scutter
posted on 16/10/13 at 08:21 PM Reply With Quote
Keep us posted on your progress.
I've just picked up locobladeracer's Alfa 12v powered Haynes roadster to complete and a engine assy for £250
(how long until someone says you could build a car for that?)
Have a look in my photo archive under MD7.
Regards Dan.
phil clegg
posted on 24/10/13 at 10:44 PM Reply With Quote
alfa v6
i have an alfa v6 12v in my haynes ,been using it for 3 years,having tried a 3.6 and a3.3 i ended up with a 3.1 diff and lsd,rebuilt engine with cams makes 1st gear an ornament,using gartrac 3 series box,have used standard injection system and has been very reliable,using a competition spinner only ,this works well with hyd clutch and no grab,you may not need to tune as wheelspin is quite a problem,santapod 3rd gear starts 13.7 100mph,2nd gear with better tyres would be bit quicker,now on toyos t1r,much better.doing autosolos just about last 8 events,the wiring for standard engine is very easy compared to most nowadays,the larger intakes of a24 valve and throttle body i am told fits,i am running two separate 3in to1 pipes with r1 cans,not quite the sound i wanted but not to noisey and slightly unusual,would prefer a sngle exhaust like one of my previous cars,may change later,anybody want any info utu me or call 07957617548
Alan B
posted on 27/10/13 at 12:20 AM Reply With Quote
That's not Phil Clegg originally from Preston by any chance?
Alan B
Markymark
posted on 27/10/13 at 09:32 AM Reply With Quote
Hi Phil
Would love to see some pics of your car sounds great.
I discounted BMW gearboxes because 1st always seems too short.
Will no doubt have little use for 1st gear too, but hey ho.
Am going to put a ballance pipe in the exhaust to try and stop it sounding like 2 triples!
Mark
<<  1    2  >>
New Topic New Reply
